Rob & Karen
I have been considering the following bulbs as replacements for the navigation lights (red and green...not anchor) on my boat.
LED Bulbs
Defender lists this as a cross reference to the Ancor 529104 incandescent bulb, which I think is the original bulb, but I have not been able to confirm this anywhere else. There is also a note about these not being for navigational use, but they seem to be much brighter (48 cp vs. 8 cp) than the incandescent. I am assuming that using white LED's behind the red and green lenses will work ok.
Does anyone know if this is all correct? Has anyone else changed out the navigation light bulbs (not the whole fixture) to LED's?
Rob
Ps. I tried to make it a short url, but it did not work. Maybe someone can point out my syntax error. If you copy the link, it does work. It is Defender item 200086 at www.defender.com.
LED Bulbs
Rob
