I had this problem in my 2002 22' CRUISER (there are a number of past postings on this situation in C-BRATS and in the archived C-DORY OWNERS' site.
The postings from owners and factory reps suggested that the water came either from the anchor locker "vent" or from screws drilled too deep for the bow stem guard. I unscrewed and re-sealed the bow stem screws and I discovered (as others have) that the anchor locker vent is simply a hole drilled through the two fiberglas molds...so whether water is coming in from the outside or draining out from the inside, its going to run down between the molds and collect under the v-berth. From my experience, both water and air can exert a great deal of pressure on the seam where the two molds are joined (especially at the porti-potti step); underway stresses can expand cracks in structure weakened by constant moisture.
A fiberglas-er (after having submitted a proposed repair to the factory and being told to do a less extensive job) repaired the crack once. When the crack and water leakage reappeared, the repair involved a lengthy and extensive drying of the fiberglas and a heavy layering of fiberglas (which the fiberglas-er did with no additional charge).
My point is not to blame the factory on design or repair directions, but to stress that the anchor locker vent must be tubed (so water does not flow between the fiberglas molds) and that any repairs should involve adequate drying of the affected fiberglas before any patching is done.
Also, I don't know how much difference this makes...but seeing the amount of stress placed on that v-berth step joint by air and water, I do not use that access plug that is under the porti-potti area (the plastic plug is in a box somewhere....and when things "huff-and-puff" in that air space between the molds at the bow, I just get a little bit of pink styrofoam flaking in the cabin!!).
therevdr on "DRIFTWOOD DREI"
