That I'm going to post my fuel numbers. I must say that I'm darned tickled with them. I went by boat from Olympia to E Q Harbor Services on Cornet Bay for service on the main and kicker. EQ was the ones who installed the motors. I am 100% satisfied with the installation and the service that EQ has provided on my Honda 200 and 15HP motors. I had 280 hours on the main and probably 4 times the hours on the kicker (at the very least). Carl did a great job and I would recommend EQ to anyone. The big motor ran very sweet on the way home. Now the mileage numbers. I filled each tank with fuel at a local gas station in Chehalis. After completing my trip I filled up at the same gas pump and the boat was on the trailer both times to get the actual fuel consumed in each tank. The way up was fairly calm but I couldn't really get to the sweet spot because of all the debris in the water. My best fuel economy is between 25 and 30 mph. I traveled 115 surface miles (by GPS) to Cornet Bay using the port tank. It took 5.25 hours and 29.6 gallons of fuel. That produced 3.9 mpg at an average speed of 21.9 mph. At Cornet Bay I switched to the starboard tank. The way home was rough water with a small craft advisory. I traveled 138 miles back home and used 40.7 gallons of fuel and averaged 16.2 mph. My mileage home was 3.4 mpg. I had the trim tabs down for about 2/3 of the way. Carl also did the tune up with the starboard tank so a little fuel was consumed then. The total trip was 253 miles and 70.3 gallons used which is 3.6 mpg average. The Honda factory fuel flow/consumption gauge was very close at 71.2 gallons of fuel used. Like I've said before, my boat averages a little over 3 mpg out in the ocean but the conditions out there are a lot worse than Puget Sound so I would expect to get poor fuel economy there.
Forrest
Forrest
