gljjr
- Joined
 - Jan 27, 2005
- Messages
 - 908
- Reaction score
 - 0
- C Dory Year
 - 1982
- C Dory Model
 - 27 Cruiser
- Hull Identification Number
 - 27003
- Vessel Name
 - Migratory Dory
Seabran,
I think it all depends on if you want to spend the money. The vented brakes are a much better way to go IMHO. The venting will allow you to have cooler brakes and that means that they will stop better! At the very least, if you keep the non-vented brakes make sure to have the highest quality brake fluid you can. IE: Dot 4 if your system can't use Dot 5 or Dot 5 if it can. Dot 5 will work much better if it has the correct seals in the system. The reason is that as a synthetic it has a higher boiling point. Since your system will have hot brakes the higher boiling point will greatly affect how well your system will work!
If you ever notice after a long hard stop that your trailer brakes don't seem to be working make sure and change the fluid in the system. Once brake fluid boils it is worthless IMHO.
