Wandering Sagebrush
Free Range Human
Captains Cat":2ru2velv said:digger":2ru2velv said:Had the same prob with stalling at very low idle. Turned out that the impeller needed changing, with overheat at low rpms initiating overheat sensor shutting down the motor. At higher speeds, more water would cool the engine enough to not allow overheat. Ron
Doesn't sound like either one of their engines will run long enough (or even start) to overheat, sounds like a different problem... Automatic choke or idle set too low.... :disgust
Charlie, it was low idle on my 15. On the original post about the BH 8, I suspect the plug, but will get it out to the pond to be sure. I blew out my back yesterday (thank goodness for Vicodin and Flexoril), so it may be a bit before I do that.
