Phil Barnes
Has anyone transom mounted a 9.9 hp or 15 hp kicker on a 25 with trim tabs? I have seen several using a mini jacker to push the outboard out to provide clearance for the trim tabs. Most of the mini jacker installations require a 25 inch shaft (extra long). If there is room to mount a kicker on the transom, will a 20 inch shaft (long shaft) work?
Thanks in advance!
Phil
Thanks in advance!
Phil
