I was coming back from a couple of days cruising yesterday and after weaving round the ferries in Swartz Bay I headed through Page Passage. For those who are not too familiar it's an interesting little pass with unforgiving rocks on either side. The tide rips through at a good clip when running and i could see the effect. With 3600 on the tachs I was showing 14mph through the water and between 8 and 9 mph SOG. The water was doing that interesting "boiling" and whirlpool trick and throwing the boat around a bit. I was keeping an eye on the rocks and then the high temperature alarm on the port motor went off. Boy, is that LOUD! I killed the motor and took the starboard one up to 5500. I guess I had some momentum because the speed only dropped to about 9 or 10 through the water and I was able to clear the passage under good control. Once through I stopped the starboard motor and lifted both so the kelp could drop off the port water intake. Thinking back I know I was ready to restart the port motor and risk an overheat if one motor hadn't done the trick but here's a couple of questions.
Has anyone run a motor with the alarm sounding in an emergency and if so, how long have you got before it seizes or ?
I would have reduced drag by raising the port motor but was too busy controlling the boat in the current. Any experience as to how high the steering linkage will let you go if you do need to run on one motor for a while?
Thanks
Thanks
