Gulfcoast John
Well-known member
- Joined
- Dec 14, 2012
- Messages
- 1,184
- Reaction score
- 48
- C Dory Year
- 2010
- C Dory Model
- 255 Tomcat
- Vessel Name
- CAT 'O MINE
Hi Brats! A messy lesson for those few with a Jabsco 18590 series black water sewage macerator pump... there are some issues to be aware of which I'll post as a new thread to make future searching easier.
This pump is widely used in trailer boats (which usually have a freshwater sewage rinse system) and sailboats (where saltwater use causes smelly heads, crusting on pipes, corrosion within pumps etc). The pump housing is held together by 4 incredibly skinny bronze tapped rods which corrode in the corrosive environs of human waste and water (esp saltwater). It doesn't take much Net searching to find unhappy buyers who don't get a year before it shows The Initial Early Evidence of Impending Failure (namely, to fly apart spewing sewage all over everything in the compartment when turned on). The bronze rods corrode and break. If you have one, it will likely be mounted under the galley sink starboard side and be plumbed to to the gravity blackwater holding tank and only used when the diverter valve is set for overboard discharge when at least 3 miles out to sea. Jabsco recently changed out the bronze rods with acorn nuts to stainless steel rods with hex nuts, although there may be old models in the retail pipeline.
The macerator pump looks like this:
https://www.amazon.com/Jabsco-18590-209 ... 18590-0000
The old-style skinny bronze structural rods look like this:
https://www.amazon.com/Jabsco-Self-Prim ... 18590-0000
The stainless retrofit structural rods look like this:
https://www.amazon.com/Jabsco-Older-185 ... 18590-0000
All from Amazon for my conveinience, shop your own fav sites.
BEFORE ever turning on a vintage model not within the 12 month warranty (or even if it is), try turning the acorn nuts with your fingers...if they turn, that bronze rod has broken. I was lucky that only one of the 4 had broken, which allowed a drip leak we could smell but not a sewage slinging festival under the galley sink, where we keep kitchenware etc and you probably do to. I found that boaters more experienced than I advised rebuilding this unit every 1-2 years. For a pump whose job in life is to move sewage, you will very impressed, as I was, at the quality of the gaskets, which are made of very good quality...well, er, ahem...paper. For various reasons including incompatible above -water through hull size I can't replace this pump with a Whale unit. But I'm satisfied with the upgrade and replaced with a new unit (I'll rebuild the old one in the winter as the spare). We also had a minor leak at the diverter valve due to a slightly loose hose clamp when using a Hontoon houseboat pumpout massive pump made to empty 150-gal houseboat tanks. It was absolutely tight to a screwdriver and a Vise grip, but a 5/16 nut driver got another 1.5 turns on it and every other hose clamp down there. Lesson Learned.
I hope any Brats with this unit discovers a broken rod prior to TIEEOIF. It will save you a huge preventable mess.
And get the nut driver.
Happy Boating!
Happy Boating!
