hardee":2fxufqqs said:
A question on the "side view" system.
Would it be possible to turn that 90 degrees and have a "front" view? :?: :idea:
I like to poke around in the shallows and if that could see ahead 100 feet, with some degree of depth designation /distance recognition it could save a prop or two or maybe some gel coat. Sort of a forward looking sonar :roll:
There are some forward scanning sonars--the cheap ones so far are somewhat limited to about 3 to 6 x the depth of the water. Echo pilot and Interphase (was purchased by Garmin about 2 years ago) are the most common types. I have used them both, and are ok at very slow speeds, especially if looking for rocks or snags--not so good in sandy bottoms, like the ICW. Furuno has been working with phased arrays for many years, there are new units just coming to the market by several manufactures which may be better.
There is the $13,000 Furuno CH270 Searchlight SONAR which has a range of 2500 feet and has a dome which protrudes below the hull, and scans like a radar--retracts when you come up to speed. This is the cheapest of the rotating sonars. Furuno makes much bigger units, and Westmar also did in the past.
$24,000 WMB160F WASSP Furuno multi scan, but more for bottom, sort of like down and bottom scan, with wide beams, and far more sophisticated than the down scan and side scans. I don't know if this technology will move forward in the recreational boat market--but rumors.
Here is a comparison of the Furuno "searchlight" and FarSounder ($60,000 phased array) by Steve Dashew:
http://setsail.com/two-different-sonar-models-to-try/
Now as to the side scan--no it will not work facing forward--unless you are drifting sideways. It sends ultrasonic beams off to the side, and then a "map" is developed as you move along, so you see what went by-rather than what is ahead. I keep hoping that shortly we will see an economical forward looking sonar….
