matt_unique
- Joined
- Feb 27, 2007
- Messages
- 1,881
- Reaction score
- 0
- C Dory Year
- 2007
- C Dory Model
- 255 Tomcat
- Vessel Name
- Napoleon
Well I gave it a go today. I used 4 boat stands placed aft on the 3.5" sections of flat surface on each side of the sponsons. I removed the "heads" of the boat stands and just used the stand structure with pieces of pressure treated 2X6 wood (about 10" in length) and thin pieces of stainless steel between stand and hull.
The stand height measured 31" off the ground. I lowered the front of the trailer down, inserted the stands/wood/steel, then used a bottle jack to lift the trailer. When I reached the end of the lifting span for the jack, I would crib the trailer, then add cribbing under the jack and repeat. I raised the front of the trailer 31 inches off the ground.
I added three pictures in my album on page 2. You can see from the pictures I had a decent clearance under 2/3's of the hull aft. Unfortunately I was not able to get sufficient clearance to prop wood between the hull and trailer such that when I lowered it down it would raise the bow. I was attempting to put wood between the trailer and hull so that I could access the bottom of the knife edge forward.
It was a lot of back breaking work and took several hours. The limited lifting range of the bottle jack and the necessary double cribbing (under trailer and under jack) is what is so time consuming.
I will have to get the boat lifted off the trailer with a crane at a yard and put on blocks to get the work done. Ah well...it was successful in terms of lifting the rear 2/3's off enough for a paint brush but not high enough to do anything forward.
