Active member
sorry les. the nissan is 27 lbs lighter in the 9.8 . You should see the way I lie about fish. What is the differance between the nissian and the Tohatsu other then about $200 from what i have seen while shopping?
starcrafttom":3eia3450 said:sorry les. the nissan is 27 lbs lighter in the 9.8 . You should see the way I lie about fish. What is the differance between the nissian and the Tohatsu other then about $200 from what i have seen while shopping?
Valkyrie":34qo3jsn said:Les,
Would you recommend the 10" power thrust prop ove r the standard prop on a BF8A on a 22 for the intended use of trolling and an emergency back- up in case the main engine would go down?
Nick
"Valkyrie"
