mendocoast
- Joined
- May 18, 2023
- Messages
- 7
- Reaction score
- 0
Hello All -
Just acquired a 2006 22' Cruiser in California. After I received boat, which is after I transferred title, I noticed that the DMV paperwork shows a zero in the third position of the HID as opposed to the letter 'O'. CD0 vs CDO, the latter I believe being the actual mfg code. When I asked the DMV I got several different explanations.
1) The record for the vessel with the zero in that place shows up regardless of whether enter zero or the letter O. And they claim its been registered that way since 2015, presumably when it was first registered in CA.
2) CA doesn't allow the letters 'I', 'O' in a vessel ID, presumably because of confusion with similar number. When I asked someone at the C-dory and did some reading, I see that these letters as well as the letter Q are not allowed, specifically in the serial number portion, positions 3-7
3) One DMV rep said I should request the change, the other said I shouldn't because it wouldn't be allowed.
Noting that when I run a boat record search, it only recognizes the version with the letter 'O' in third position.
When I look at the stamped HID in hull and the plate under eyebrow it I don't see a difference between that character and another zero in the date portion of the HID so I can't verify the distinction based on that.
Anyone familiar with this issue? Recommendations? Concerns? Thank You
