mikeporterinmd
- Joined
- Sep 15, 2006
- Messages
- 645
- Reaction score
- 0
- C Dory Year
- 2002
- C Dory Model
- 22 Cruiser
- Hull Identification Number
- CD022029B202
- Vessel Name
- Shelly IV
CAVU":2vfiznkp said:Everything I have read would indicate that all the connections should be crimped and not soldered? I think the reasoning is if the wire heats up it could melt the low temperature solder from the connection and cause arcing. I can't remember where I read this. Anyone know if there is a "rule" on this?
You shouldn't solder because a hard spot is created between the solder
and the flexible portion of the wire. If the wires flex at all, then the
wire will break at that point. So, soldering on items prone to vibration or
flexing wires is not a good idea.
Having said that, I just got done soldering the tiny wires that from a GPS
into an Icom 422. The wires on the Icom are coaxial and very small.
Soldering these is really the only option. The resulting wad of tape I
needed to ensure the wires don't flex and break is substantial. Honestly,
if someone gets hurt because the wires break on someone's 422 and
Icom gets sued, I hope the plaintiffs win. Using such tiny wires on a
life saving device is stupid. I should replace that radio.
Mike
