Well-known member
- Joined
- Oct 2, 2011
- Messages
- 5,143
- Reaction score
- 92
- C Dory Year
- 2009
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- UWH25301J809
- Vessel Name
- C-Traveler
So, my Honda EU2000i finally died. I was running it the other night in the rain. Not sure if that killed it or not. It had run fine earlier in the day, and for about an hour prior to shutting down. When it stopped on it’s own, it was if I had just pressed the stop switch. (I had installed a stop switch on it since the fuel/switch control on those units shut the unit down with fuel still in the carb.) The fuel was good. And while I read something about the carb jets getting fouled, I believe that is if the unit is sitting unused. I even tried disconnecting the stop switch thinking maybe that had gotten water in it. Still no joy on starting the generator. It was getting fuel to the carb and even smelled flooded if I pulled the starter cord enough times. I’ll putz with it when I’m back home, but in the mean time I decided to buy the new Honda EU2200i Blue Tooth model. $100 more than what I paid for the 2000 15 years ago. So while pricey, at least they haven’t increased in price.
Honestly, I don’t really see all the hype about the new ones. Other than the 200 additional watts, a bit bigger oil drain/fill, a fuel shut off valve that allows you to turn off the fuel before turning the knob all the way to stop, and a few nice stats to know from the Bluetooth app and being able to shut it off remotely with that app.
But there are a few items that bother me. First, the newest models with blue tooth have removed the 12vt receptacle. I did use that once or twice in 15 years to charge a battery, so guess it’s not that big of a loss. But the following warning in the operating manual got my attention. Perhaps they have had problems with those of us that are using them as a boat generator.
Vehicles and Transportation Hazards
• Do not operate the generator while it is being transported or while it is
mounted to any type vehicle, trailer, or boat.
• Do not operate the generator when it is in a storage, cargo, or security
enclosure, including any RV generator bay.
• Always completely remove the generator from the vehicle, RV, truck, trailer,
boat, other equipment or structure during operation.
• The generator must remain stationary while in operation.
Now this was from a recall in 2019 and hopefully all is well. But still caught my attention:
Update: Honda has recalled 345,000 inverter generators because they pose a burn hazard to consumers. Honda portable generator models EB2200i, EU2200i, EU2200i Companion, and EU2200i Camo can short-circuit around salt water, causing them to smoke and potentially catch fire, according to a notice from the Consumer Product Safety Commission. A number of these same generators were recalled last year for gasoline leaks, as we first reported below on March 22, 2019.
Anyway, so far the new generator has done what I purchased it to do in the one evening I ran it. Hoping for many years of uneventful operation of it. And perhaps I’ll get the old one running for a spare around home. Colby
