I was looking over the Honda marine site this morning, comparing the 75efi and 90efi. They have test results for both motors on the C-dory 22 cruiser. The 75 outperforms the 90 in speed / RPM and MPG up until about 4250 rpm where they are equal at approx. 22mph (the 75 get slightly better mileage). Above 4250rpm the 90 goes faster with a 2.5mph advantage. Seems like the 75 is the way to go, but I'm sure there is more to it, help me understand.
The 75 was tested with a 13 3/4 x 15 in, 3 blade prop, aluminum (3086lbs)
The 90 was tested with a 13 1/4 x 17 in, 3 blade prop, stainless(3214lbs)
and a 13 1/4 x 18 in, 3 blade prop, stainless(3214lbs)- (this set-up did much worse)
Did the weight difference of 128lbs make the difference or the different prop, would the 90 do as well if it had the 13 3/4 x 15 in. prop?
