Have to get a new HIN number?
Oly
Dec 3, 2007
26
There were a series of posts in 2012 about "13 character HIN" and I thought about replying to it but since this is not really about 13 characters but a new problem that has bubbled to the surface, I am starting a new subject.
An issue has come up that I think is important to many boat owners. I don't have a C-Dory but I was told by my county auditor's office (that handles boat registrations) that about 19,000 letters have gone to boat owners in the state of Washington titled: "NOTICE: New Hull Identification Number (HIN) Required." My boat is a Rosborough, made in Canada, which is the cause of my particular problem but I am sure there are not 19,000 Rosborough owners in the state. In fact, there was another person talking to the clerk as I waited in line and he had the same problem as I did--they were requiring a new HIN--and he did not have a Rosborough.
The letter was from the Washington State Department of Licensing (DOL) saying that I wouldn't be able to renew my registration (expires in June) until my Hull Identification Number (HIN) was changed. The Coast Guard says according to their new rules that apply nationwide, they can "only be 12 characters" long. My Rossi's number is 12 but it also has "CA -" in front of it and the DOL has the "CA" as part of the total HIN, thus 14 characters. This is an error on the part of the DOL but it hasn't mattered until now.
I went to the county auditor's office and they said that they would create a new HIN and I would then have to take that new number, make a "permanent" HIN and affix it to the boat (the letter recommend "molded"), and they'll send me a new title with the new number. The new number should be "applied adjacent to the original HIN" and thus there will be two HINs on the boat.
My HIN plate says: "CA - ZRL25446A808" and I have emailed them a photo of it. They have it in their records as "CAZRL25446A808" and thus 14 characters and that is why they say I need a new HIN. The "CA" is the "country of origin"--Canada--and per the Coast Guard rule, is not part of the HIN. However, the auditor's office has taken this to mean I have a non-compliant HIN and must be replaced.
Huh? Just because the "country of origin" is on the plate on the transom? A person at DOL said all I had to do is block out the "CA -" ("just put tape over it") and the county could redo the title with just the actual HIN in 12 characters. When I told the clerk at the auditor's office that DOL told me that, I was told that had to be wrong since I'd be "defacing" the HIN (subject to Coast Guard action) and they couldn't just change a title HIN, they had to reissue me a new one. Since the HIN has information about the manufacturer, what # boat it is that they've made, and the date of manufacture, I fail to see how they could duplicate that information without just recreating the same number. If they made up a new serial number, how do they know they aren't duplicating an existing number and what is gained? Doesn't this also defeat the Coast Guard rule about how the HIN must be structured to provide the information about the manufacturer and date?
They said unless I re-did the number, I couldn't get new registration tabs and I wouldn't be able to sell the boat. So selling the boat with some sort of "new" title and two HINs on the transom wouldn't raise eyebrows of a buyer as well as not having the original title but one created years later?
After a certain amount of back and forth, they agreed to contact the state DOL and see what they say. I got a call later and they said DOL was "looking into it" and maybe I'd get a ruling on Monday.
So, if you too are having this problem I suggest you hold off getting a new title until this is figured out. I'll post my update later.
I saw this same post in the Rosborough forum. The CA is not really part of the US HIN number, since in the past the Rosborough were made in Canada. I have not heard of any other state making this an issue. By international standards your boat has a valid HIN--see below.
The state cannot issue you another HIN number, unless they declare it a "home built boat". This is a federal issue:
33CFR:
Sec. 181.35 Removal of numbers. No person may remove or alter a number required by this subpart unless authorized by the Commandant, U.S. Coast Guard
Good luck with your endeavor.
https://www.law.cornell.edu/cfr/text/33/181.35
(There are a number of other points of HIN, in all of section 181, mostly dealing with manufacturers. Might even send the whole 181 section, with yellow underlining of the pertinent issues for your boat. )
Another point is:
Country Codes: The International Standards Organization (ISO) has accepted the format of the US HIN except they have added two additional characters as a code for the country of origin. The code for the USA is US. For Canada it is CA.
(ISO 10087: https://www.iso.org/standard/37497.html
I would include with your letter of objection both of these codes!
I just had the same runaround about the HIN.
Try going to a 'licensing agent', not the county auditor. The licensing agents are private businesses that work for your fee, they are not government agents.
You could try taking a photo just showing the 12 digit HIN, omitting the CA. Submit that photo and request a 'corrected' title.
I had the HIN problem with my trawler, but my problem was not enough digits. When I purchased my boat 10 years ago, the state DOL left off one digit at the end of the HIN on the title. A photo of the HIN and lots of explaining at a licensing agent got a corrected title issued.
Steve, to help out a fellow Cbrat I will offer to take the Rossi off your hands- bring it back home to Canada - you can buy a new Eastern USA Rosborough and all your troubles will be solved!! :mrgreen: :mrgreen:
Good luck untangling the red tape!
Rob
Just another way for the state to make a buck . Sounds like Massachusetts aka Tax-a-chussets!
Good luck Oly.
Good luck Oly.
Amen. :evil: Except here we are in the Socialist Republic of Washington.
Solution: move south, to OR!
Well, there is that income tax thang! :wink:
No, they will not charge any money to change the HIN on the title so not all perceptions are real. My beef is with the hassle and that it is an error to require changing the HIN (for legal reasons that have been pointed out) and errors should be fixed, regardless of the source.
I did suggest to the clerk at the auditor's office that maybe I could just go to a private agent where they might not be as fussy but the problem is that even if I get my new registration, the title is not in compliance and could be a problem when selling the boat. I'm also in the computer as being non-compliant and thus even private agents can't issue me new registration stickers. The title needs to be fixed since when it was typed in about 10 years ago they left the "dash" out and converted a 12 character HIN to a 14 character HIN. I suspect this was the protocol at the time and the CG never was aware, or maybe cared, but now the both are aware and care.
When I went in to renew my registration, I asked about the HIN on my boat. I was at a licensing agent office, but was told that my HIN was compliant and I Don't need to worry.
Good luck with the Rossie.
SleepyC :moon
