You know I never considered the weight variance between a two stroke versus a 4 stroke. When I ordered the 22' angler I insisted on the 4 stroke thinking that there was going to be some form of ban on the two strokes on lakes such as lake Powell. I read stories of horror about bans in California and expected some of that to follow on other waterways.
My Honda 90 weights 500+ lbs. I am not sure of the weight of the same HP two stroke, but I bet it is 150 lbs. If you were to add a 115 two stroke you might very well have a good combination . Again, and motor change is going to be costly, certainly cheaper than a new boat.
I do agree that the 22" cruiser is not very fancy and then you have a minimum of a 200 lb increase in weight over the angler.
I will say the passenger seating is vey uncomfortable on the angler. I have toyed with the idea of removing the two cushions, and table and making a solid bench seat parallel with the boat.
I did ride in a 22' cruiser, however I was standing during the 1 hour ride. I never checked the seating on the port side.
Anyway I think I will contact C-Dory and see about getting a letter stating a hp increase, then I have to get the vessel capacity sticker upgraded. This seems to be my cheapest bet.
