smittypaddler
Nope, it was almost certainly not low batteries, as I was on shore power at the time. As I mentioned previously, I have two deep-cycle hours batteries and a battery charger on board, in addition to a 1000-watt inverter. I've always made sure those batteries are fully charged, fluids topped off, etc. Even as we speak, Na Waqa is in indoor storage, connected to shore power, and the battery charger is trickle-charging as needed.
If you've seen my earlier posts, you'll know I don't think much of the Wallas. When it works it's great, but when it's broken it's too complicated, for me at least, to fix. If I'd known the thing has a computer circuit board on it, I never would've ordered it with the boat. Maybe the alcohol stove isn't as efficient, but at least I'd probably be able to fix it when it broke, and not have to send it to the factory for repairs, as I had to do with the Wallas. I've heard the Wallas is safer than a Coleman propane stove, for example, because of the pressurized fuel bottles. But I run the risk anyway and have a Coleman stove and bottled fuel stored away onboard, for the next time the Wallas breaks, as I believe it will.
