Hi Bob --
As always, you make good points and I had limited my discussion previously just to the question of the new boat warranty. I fully understand that I am getting the used boat without a warranty. However, the boat has been used a decent amount and my feeling is that any issues will likely have surfaced and be detectable at this point, unlike a new boat where they are yet to become evident. I am fairly capable myself having built a 22 foot dory from scratch and completely gutted and rebuilt a 32 foot Pearson Vanguard. The boat I have under contract looks quite clean and I did not see any sign of major issues although a previous owner had fixed some things, reasonably well. For example, there had been a number of the normal rub rail leaks. This winter, I intend to pull all screws and hull and deck penetrations, remove core and fill with thickened epoxy etc. The other thing I have done is found a surveyor who is very skilled with cored hulls and who has experience with a problematic CD-22 (foam under the V berth did not cure and the core on the brand new boat had moisture) which the factory had to take back a couple of years ago. The bet I am making is that between my inspection, the survey, and the fact that the boat has been used enough, there will not be significant issues that are missed. If they are, that is just my bad luck and my problem. I am old fashioned on such things but I am not a fan of building boats with liners because they hide so much of the interior of the boat that is not available for inspection now or in the future. One of the things that I find especially appealing about the C-Dory is that it is really a simple boat. Issues that arise are generally quite capable of being fixed by a handy owner. I would have no issue tackling most wet core issues myself as you did on Frequent Sea. Besides which, with the phenomenal C-Brat site and so many boats, there is always helpful advice and counsel. There are not many problems where you will be the first to encounter them.
As you point out, the boat world is absolutely fraught with warranty issues and Luhrs is a real good example of how bad it can be.
Also on the dealer side, I completely agree with Marc. It is not easy to be a boat dealer these days. It is completely unfair of a buyer to purchase the boat purely on a price basis from a distant dealer and then try to take warranty issues to a local dealer to be addressed. Territories are territories and are to be respected. That said, one might go distant if there is not an appropriate boat in stock locally and the wait will be unacceptable but even then, if I were to do so, I would understand the warranty service implications. In general, I support local excellence because it is important to keep the smaller, local operations from being swallowed up or put out of business.
