After removing some old electronics, my boat has a completely unused accessory fuse panel under the main switch panel (in the berth). Are blade fuses and inline (along the wire) fuses of the same rating comparable, or is there a reason to specifically use inline housings/fuses? It would be cleaner and easier to use the panel (it accepts a blade fuse for each positive terminal).
I just want to make sure there isn't a specific difference between the two types (i.e. barrel fuses being for delicate electronics).
Thanks!
Thanks!
