haliman
- Joined
- Nov 30, 2011
- Messages
- 163
- Reaction score
- 0
- C Dory Year
- 2008
- C Dory Model
- 19 Angler
Took boat out to lake for the first time yesterday. Went to start motor and was having hard time with both the main and kicker but finally got kicker going and later main. I believe I was having hard time getting fuel to both as the bulbs were not getting hard but finally did. I noticed debri in the clear bowl of the fuel/water separator, drained and pumped bulb again until full but more debri. Ran both motors and mainly main on port tank then switched to starboard tank but after awhile started to sputter and died. Again I think no fuel to motor. Repeated drainage process a few time throughout the day. Bought boat in December, 2008 19’ Angler with 2008 Hondas – 90 and 9.9. Low hours on boat and motors and just had both motors serviced. When purchased both tanks were about a ¼ full and do not know how old gas was but when doing sea trial it ran good. I did fill both tanks but left old gas in. I am a newbie to all of this but now thinking I need to drain both tanks, uninstall them and clean any debri that might be in bottom of tanks. Even though I just replace fuel/water separator I will change the filter again after re-installing tanks and fresh gas. Does this sound like my issue and if so is there something else I should change out a swell?
Thanks
Thanks
