Allow me to share performance results for an aluminum Solas 15X3 four blade prop on my 22 with a 90 hp Honda 4 stroke. The three blade it was compared to was a 15x 3.5 aluminum. Based on speed log comparisons the 4 blade drove the boat the same speeds at the same RPM (within .1 nmh or so more or less)through the entire displacement range. The 4 blade required more RPM to climb over the bow wave and more RPM to match speeds with the three blade throughout the remainder of the test. The three blade at 4200 RPM will drive the boat at 18 knots. The four blade at 4200 RPM drove the boat at 14 knots.The 4 knot speed difference was consistent throuout planning speeds. Is the .5 difference in pitch responsible for the performance differences? What other performance parameters can be evaluated to determine which prop would serve best?
Mike 'Levity'
Mike 'Levity'
