Hello All:
I keep my 22 in the water all season (May to November) @ the Jersey Shore. Last year I kept the brass device used to rinse the engine screwed in - also fitted it with a screw in cap to keep a seal. After each use attached the hose to it and the engine received a good rinse; however at the end of the year I could not get the device to un-screw even though I greased it well.
This year I did not put it back in (the "yard" was able to remove the rinsing device) Now I am back to the ear muffs - If I try to unscrew the rinse screw and insert the nozzle after each use one or the other of both will fall into the drink -
How have you folks solved this?
Thanks for your advise.
Ken
Ken
