Sunbeam":1l24v6yk said:
I mentioned this in your other thread as well, but boats are typically registered/titled in state of principal use. This is not necessarily the state you live in (unless the two things coincide). For the use you describe then you'd register in Florida.
Although this is generally true, there can be exceptions. The Key is "principle use", vs where the boat is kept the majority of the year. This is especially true for trailer boats, kept in a storage lot. I have know of issues like this in some of the NE states, and in Calif. I believe it has also has been an issue in the NW. Tax collectors have employees who prowl the storage lots and marinas looking for out of state boats. They then want the personal property tax and registration fees--for example I kept a boat in Calif. However never used it in Calif, but used in Lake Powell, and in PNW. It happened to be documented, so no Calif. Reg. No worry, the tax collector found the boat. (Calif. does not require documented boats to be state registered as some states do)
The Cal 46 we kept in Sequim 5 months out of the year, but used in BC, and AK, 7 months out of the year. Washington wanted tax on the boat.
Florida as I noted above, requires registration in Florida, if you have the boat in the FL waters over 90 days. (Even if a documented vessel in another state, or the vessel is used the other 270 days out of Florida. )
Our current C Dory 22, is used more time in at Lake Powell and the PNW, but spends more time in storage in our yard in Florida, thus a Florida Registered boat.
