Larry H
- Joined
- Nov 1, 2003
- Messages
- 2,041
- Reaction score
- 0
- C Dory Year
- 1991
- C Dory Model
- 22 Cruiser
Mike,
Your calculation of about 55 cu ft to float 3500 lbs is correct. To help visualize the amount of foam required, consider your fuel tanks.
An empty 25 gallon tank would provide about 200 lbs of floatation. Two empty 25's would barely be enough to float the motors!
Floating the boat doesn't require the entire 55 cu ft of foam,however. Some of the hull structure(the core) is already lighter than water.
One way to determine the amount of floatation needed would be to suspend the boat from a scale, lower it into the water, fill with water, allowing it to sink, and check the scale to see how much it weighs underwater! Everything weighs less underwater based on how much water the item displaces. But most of us don't want to use our own boat for that test!
If you look at a CD19, you can see how much of the interior has been filled in for the foam. The sides of the cockpit and hull sides inside the cabin are covered with a liner where the foam is located.
