Robert H. Wilkinson
Active member
- Joined
- Jan 26, 2011
- Messages
- 1,286
- Reaction score
- 0
- Vessel Name
- Romakeme IV
Hi Colbysmith, in answer to your first question - foam does serve several purposes.
1/ It provides buoyancy in the event of a swamping.
2/ It helps prevent, limit, or isolate water intrusion in the event of a hull breach (holing)
3/ It strengthens the hull, adding rigidity to lessen flexing in a heavy sea.
4/ It gives you a quieter ride (esp. in an aluminum hull)
In answer to your second question - I believe all boats up to 20' are mandated to be built so as to float level if swamped. This may be why the newer 22'CDs don't have it as they are above the 20' limit. I did read here somewhere that CDs have been known to float bow up with the stern under water when swamped. An Armstrong bracket would fix that. This is one thing I like about the 22'Seaskiff (Rosborough) - you can custom order the hull configured for an I/O (full transom) then add an Armstrong bracket with your outboard. Lots more room in the cockpit without the outboard well, and a swim platform (not to mention the other benefits to a bracket)
Last summer I met a fellow boater from Buffalo who told me an interesting story. He had just exited the Welland canal into Lake Ontario when he was swamped by what he described as 2 converging waves. Despite loosing his windshield, his glasses and his Sea Ray being swamped - his engine kept running - his pumps kept pumping and with him bailing (his wife took the helm because he was blind without his glasses) they were able to clear the hull of water and continue under their own power back into port!!
Without Sea Ray's use of floatation foam I may not have ever heard that story!
Regards, Rob
Regards, Rob
