Fishing using the autopilot
jkidd
Active member
Oct 23, 2006
1,684
7
2007
CDo22670C707
Voyager
I had a great time two weeks ago fishing at Yellowstone using the GPS and the autopilot. I started out putting a waypoint a half a mile or so in front of me and telling the autopilot to goto that. Then I would turn around and goto a second one in the other direction. Then I decided to try putting in a route and following that around part of Frank Island. When I got to the end of the route I would tell it to follow it in reverse. That's a great way to fish let the boat drive itself and just watch for other boats and the poles.
But what did you catch and where's the pictures? That's the important part! :lol:
Now you're talking!
How did your auto pilot perform in terms of accurateness? my c-80 and st 6000 raymarine would skip to the next way point 400 to 600 ft before I got to the way point I was headed to. who close did yours get you?
Mine was around 50 to 60 feet when it would switch. Speed could play a part in that as well, but I haven't watched that closely. I was reading in the book and I think there was a setting that you could change to adjust that. I also have the Tach input switched off so I can use the big motor or the kicker with the connecting rod.
yeah thats a lot better then my older c-80. I did have it set to the lowest setting and it just would not work for me, beyond its abilities. I am sure the newer units perform better.
Tom
I'm very happy with the way things worked. From the picture below the bottom track is were I came to the island and fished using the remote to steer. Then I followed the route and then reversed and followed the route back. You have to zoom in real close to tell that there are 2 track lines between the way points.
yes that looks good. thats how it should work.
man some day..............someday that woud be sooo nice to have
Use autopilot for fishing is good idea; it makes it easy and interesting. When boat turns it automatically applies helm to bring the craft back in line with the course for which it has been programmed. Purchase a good autopilot is depending on the size and weight of boat, as well as the type of boat steering system.
