bshillam":12pqdbyb said:
So I've found that G-5 fenders are a great size for the CD22. Love the coverage and the ability to tie them to various locations. However, in the cockpit they take up too much floor space. Does anyone have some bright ideas on where to store them? Has anyone had experience with those stainless steel double brackets that hold two of them? I was thinking of mounting one on the radar arch but thought lets see what other ideas are out there.
bshillam-
Those stainless steel wire brackets for fenders are usually mounted up on the foredeck along the bow rail about half way back to the cabin on larger boats than the C-Dorys, which have their bow pulpit and side rails extending back aft to the main part of the cabin or further.
Putting them on the small bow pulpit on a C-Dory would make them pretty inconvenient.
Can you store yours in the space between the gas tanks?
I store mine in the space under the engine well and lazarets above and beside the gas tanks and the hull on my '87 CD-22, putting two on each side.
Newer boats with larger tanks and/or solid tank covers made of Starboard may not have easy access to this space.
In that case, I'd try storing them by laying the fenders down in the engine well with their lines tied down securely so as to not lose them overboard in rough weather.
You can also store them upright in a couple of 5-gallon buckets in the back corners of the cockpit. I also sometimes do this, as I keep two of tthe buckets there to store the aft mooring lines, sponges, brushes, etc. in.
Not a lot of empty space aboard a C-Dory!
Hope this helps!
Joe. :teeth
