This weekend I went to our lakehouse. I took my boat out for a short trip on Saturday afternoon without any incident. I had used my boat two weeks earlier and, like last time, the engine started without any issues. This morning the engine started fine and I left the dock. Shortly after leaving (about 10 minutes) I noticed that my fathometer was flashing weird readings. I stopped - but left the engine idling- and looked to see if the transducer had caught something. Nothing so I went back and noticed when I put the boat back in gear that the tach read 0. I started back home and noticed later that the tach panel eventually went dead altogether and no other electronics would work (engine trim/tilt, fathometer, tach panel, etc.). The engine continued to work fine.
Back at the dock I turned off the engine. I checked for obvious blown fuses and didn't find anything (although not an exhaustive search). I restarted the engine and all appeared okay. I shut it down and tried again. This time all I got was a clicking sound as if the battery was dead. I tried switching to the other battery -- no luck. I didn't have my voltmeter but I did have a simple meter that plugs into a cigarette plug. Both batteries appeared totally dead ~7V each.
I hooked up the charger for a couple of hours. I was able to restart the engine and all the gauges worked. However while I was running the engine I left the battery meter on and noticed, while running, the battery was dropped rapidly in voltage (from 11.6V - only charged for two hours- to 8V). I shut off the engine and noticed the same thing happen when switched to the other battery.
I have two interstate marine cranking batteries since I usually just go out for short trips. I purchased them one and half years ago and I try to keep them charged. I turn off the battery switch when done and I don't have any equipment running when I leave (e.g. a bilge switch). I usually dont run with battery switched to both. It is possible that I did this a couple of weeks ago but I can't recall.
I can't figure out why both batteries drained and how so quickly. At least I think it was quick since I didn't check the voltage before the trips but the engine fired up fine. Also, wouldn't the gauges, etc. continue to function with dead batteries if the engine is running?
My only guess was that my alternator has gone out and that over the last few weeks the batteries have slowly drained out.
I have a 2003 Yamaha 90. I am hesitant to buy two new batteries without troubleshooting more.
I'd appreciate any advice or help. If it is the alternator is there any easy way to confirm? Is the alternator an expense repair?
Many thanks in advance.
Karl
Karl
