Pat,
You probably need to take your boat to someone equipped to troubleshoot electrical problems like yours.
Without a lot more information I can't help you other than describe how I would troubleshoot it. I am thinking that you may not have the test equipment needed.
WARNING: Following a detailed test procedure like the one below could make you hair hurt and / or fall out.
Rule #1- Never assume anything; Methodical measurement is the quickest way to find where your current drain is coming from unless you luck out.
Test Equipment:
- DVM (I use Fluke) You can buy a reasonably decent, inexpensive DVM at LOWES and it would be a good investment to troubleshoot any future DC or AC electrical problems for your boat, house, car, etc. You might also want to buy a basic book on electrical circuits.
- DC clamp on current probe: this will save a lot of time because you can quickly clamp it over any wire and directly measure the current draw (AMPS) in that circuit. Unfortunately, these are too expensive for a one-off troubleshooting situation. METHOD 2: Purchase a .1 OHM, 100W power resistor at Radio Shack and measure the drop across it with your DVM to read AMPS directly. Example, if you read 1Volt, then your circuit is drawing 10 AMPS (I= V / R) ie. 1V / .1 OHMS = 10A. The resistor introduces a slight measurement error but it is insignificant in this case and you can measure up to a little over 30 Amps with this kleuge.
Strategy:
What you want to do is start at the battery and isolate which circuit is drawing the current when everything is supposed to be OFF.
1. First, test each battery to confirm full charge (IMHO that the chance that two new batteries are damaged or bad is possible but remote; some electrical fault is draining your batteries. Yes, I am breaking my 1st rule by making an assumption)
Fully charge both batteries and confirm that they are charged to 13V + with no load on them. The charger will create a surface charge that would eventually bleed down to about 12.7V.
I would start troubleshooting the Wallas since that is where you noticed a problem to begin with.
One question: Is the Wallas drawing any current when turned off (you know that is drawing > 5A when you turn it on but let's save the smoke test for later.
2. Determine which battery (should be the starter battery) is connected to the Wallas. There should be a fuse (~15 - 20AMPS) between the battery and the Wallas if it is connected as the factory requires (#12 Red wire). This may or may not be the case since you have some battery switch bank banjo work connected therein.
3. Set your DVM to a scale that will read 10VDC and clip the DVM leads across the resistor for all of your measurements. Find a convenient (relative term) location to connect the .1 ohm resistor in series with the circuit that feeds the Wallas. You could start by disconnecting the +12v RED main cables from both batteries and then clip one end of the resistor to the red battery cable and momentarily touch the battery Positive terminal with the other end of the resistor while reading the voltage (current) since this is a easy connection. Record your reading.
If there is no current, then try the identical test on the other battery.
Determine from which battery current is being drawn and how much.
4. If any significant current is being drawn (say > .1 A or so), then try to isolate the source by disconnecting loads one at a time, starting with the Wallas. If significant current is being drawn, disconnect the Wallas by removing the main fuse and determine if the current still flows.
5. If the Wallas is drawing significant current when switched OFF, then the problem could be one of several possibilities including: a low resistance between positive and ground in the wiring or connectors, a low resistance on one the Wallas circuit boards, or a component such as the pump.
6. The fact that the smaller 5A fuse is blowing indicates a low resistance in the Wallas or in the wiring /connections associated with it. I use the term " low resistance" and not "short" because a short is Zero ohms.
7. If the problem is confirmed to be associated with the Wallas, I would disconnect everything from the batteries and use the OHM scale on your DVM to determine where the low resistance is located. Set your DVM to a full scale of 10 OHMs to begin with and measure the resistance between the connector terminals where the red and black main power is connected to the motherboard. If this reads less than 1 ohm, then something has likely gone south on the Wallas. I assume that you would send it to Scan Marine and not troubleshoot it further. I am nuts and would definitely troubleshoot further.
8.If the Wallas checks out ok somehow, then we want to reconnect the battery from which current is being drained and systematically disconnect devices at switch and / or fuse panels until the current drain goes to zero.
9. Determine which device is causing the drain and disconnect it at the a convenient location to verify that the current drain is gone. Warning: Do not use your DVM on the OHMS scale with power on the circuit; disconnect all power at the batteries to be safe.
If you want to pursue this, send me an email and I will help you. If you lived a lot closer, I would come over to help diagnose further.
I hope this helps rather than confuses you.
Good luck,
Richard
:roll:
