- Joined
- Oct 23, 2003
- Messages
- 5,335
- Reaction score
- 13
I'm on the fence here, but it seems to me a lateral impact of sufficient force to bend the hardened steel shaft would go right through the aluminum blades in an instant and apply its force onto the hub which will not cushion the impact much more than a stainless blade. Simply put, I think if you swing the sledgehammer hard enough to bend the shaft it won't make any differene what type of material is between the shaft and the hammerhead.
I have a stainless prop for my 130 with too small a pitch, but I have used it when heavily loaded and when a blade on an aluminum just up and fell off I used the stainless until I got a replacement. If it was 15" instead of 13" I would use it all the time. One of the most frequent complaints about the much heavier SS prop is a damaging "clunk" when shifted in/out or between gears. I didn't notice that much myself.
I have been lucky enough to avoid anything big enough in the water to damage a prop, so I would still buy aluminum if I needed one simply because of the cost for SS.
