Dogon stolen Idea
catdogcat
Stole this idea from Dogon Dory. Only difference is that I thought I would save $$ by using a block of wood that I covered in fiberglass, sanded then painted. Total cost: $25.00. Had to raise the kicker because of the front of it rubbing against the steering cable after the new Yami install.
Link
The mount looks good.
Have you had any problems with your main hitting the kicker when turning? I have broken a couple of parts on my kicker because of this and am wondering if a mount would help.
Steve
I made a custom arm that connects the two and they aren't hitting. If the bar is disconnected and the two motors are turned in opposite directions they will hit. Hope that helps
