The 2004 bilge pump compartment is located in the cabin aisle center and is sort of a "step to the cockpit. The opening to the bilge from the cockpit is in the center under the door. The 99s have the opening in the center under the door but the bilge pump compartment is under the sink ( I think). At some previous time the 22s had the pump under the sink and the opening toward the starboard side. Prior to that the bilge pump compartment was outside the cabin at the starboard side of the cockpit. My history (except 04) is all from this site posts and pics so subject to any and all revision. The type of pump the factory installed also changed from a Rule pump with a built in timer switch to a Rule pump with a built in float switch.
I have two pumps located in the stern. They are the same Rule pumps with a built in float switch as mounted in the midships location. The float switches in these pumps don't activate until they are about two inches deep. My stern pumps have never activated except for testing. My midships pump will activate to pump out rain water or green water. Even when I am in the stern, wtih twins, full fuel, etc. the midship pump will activate first. It has a deeper well and so it activates first. If I am in the cuddy the water always runs to the midships pump first. So I am very glad to have the midships pump and bilge and the stern bilges as an emergency back-up.
I think the worst historical configuration was having the opening to the pump compartment off center. A number of brats invented solutions to that one.
Bilge pumps are also discussed in many other threads including
DoD's manual pump,
The stainless steel super sucker,
Other sucker pumps,
The drain channel beautifully dug into the hull
and some other brat creative solutions. Search is not working for me at present but you should find some help and photos in the forums.
Regards,
