I wanted to install the 14# Delta Fast Set right away, that's why I bit the bullet and bought the spendy boom bail from West Marine. If you google boom bail, there was an online store who sold a similar size bail for $26.00. The second option would be to take the old bail off, measure it for thickness and width of the strap, and have a metal fabricator fabricate one for you, with just a little more length, 4" to be safe. It's just a simple strap with two holes drilled in and bent into a U shape, the hole size on the bail I bought was 5/16". It would probably be fairly cheap to make one of these.Jazzmanic":b1n44dla said:Timely question. I just changed my anchor to the 14# Delta Fast Set. I had the standard anchor roller and it didn't quite fit under the bail. I found a replacement bail at West Marine. Very pricey at $42.99 but half the cost of the cheapest anchor roller. By the way, the bail is called a boom bail and is designed for the boom on sail boats. The size is 2 1/4" width by 3 3/4" length and made of high quality stainless steel. You can find it in the catalog but not online.
Sorry HiCap, I can't give an answer for the Manson Supreme.
