Active member
- Joined
- Mar 1, 2005
- Messages
- 7,508
- Reaction score
- 17
- C Dory Year
- 2007
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- TBA
- Vessel Name
- "Wild Blue" (sold 9/14)
We have 50' of chain on our CD-25. The boat is lightweight with considerable windage, so it sails around some at anchor. Regarding scope, we use more than 5:1 if any wind is forecast, usually using 7:1 to 10:1. In a tight anchorage, we see what everyone around us is doing before committing to more than one anchor, so we aren't swinging different from other boats. I guess we also do a Bahamian mooring (two lines off the bow in a V") a little different from most: I prefer to not attach those lines together, so either rode can be adjusted for length as the wind changes direction or speed.
We use a Delta as our primary, a danforth as our second anchor.
We got to experience some of that Florida norther at anchor stuff. Along with Brent and Dixie (Discovery), we were in a crowded anchorage in Boot Key Harbor, when authorities chased people in half the anchorage out, because of a plan to start installing mooring balls... in a few days. During a norther with winds gusting above 40 mph. The result: twice as many boats in half the space. Even with two anchors out, Wild Blue swung more at anchor than most of the other (bigger, heavier) boats... we had to use a shorter scope than I would have liked because of the crowded conditions. Fortunately, with our shallow draft, we could get closer to the mangroves than the other boats.
The downside: someone with a boat that looked like ours had been in the anchorage the week before - they drug anchor through the sea-grass and generally created havoc amongst the people anchoring there. And, of course, they all thought that was us. :disgust
During that particular blow, the winds were so nasty that they flipped our dinghy, putting our dinghy motor upside down in the salt water! The shuttle boat service in Boot Key Harbor had ceased running due to the weather, but gave us a ride to shore so we could get the dinghy motor attended to right away... with the understanding, "If you aren't back in an hour, you are on your own to get back to your boat." Understandable. Joan stayed on the boat to keep an eye on the anchoring. Brent went with me to the outboard shop. Another boater onshore gave us a ride to the shop, the shop mechanic gave us a ride back to the marina. The shuttle boat driver said, "This is the last run until the weather breaks!"
It was two days before the wind let up. We took turns on anchor watch, neither of us getting much sleep, not able to get to shore. Even with two anchors out, the boat swung around uncomfortably. Numerous boats in the anchorage drug. Being closest to shore, bow into the wind, we didn't have to be concerned about anyone dragging into us, but there were times when boats beside us swung close enough for concern.
Anchoring isn't a "fixed situation" that is an always. The situation changes with the weather. I haven't checked how much we "sailed" at anchor - interesting to see the distance covered in Roy & Dixie's original post on this thread.
