No I'm not on drugs. I have a few cracks that I need help with. The first one showed up last season and I monitored it's behavior this season.
The thing that has me scratching my head is that where the bulkhead meets the hull it's caulked with a flexible sealer and then gel coat was applied over top. This caused the gelcoat to flake off during hull flexing. Part of the seam is glassed. The large crack I'm assuming is becuase of too much flex possibly caused by the lack of glass and resin? This isn't the only place on the boat I've found gel coat over sealer and it's flaking off too!
When under way the flexing of the hull causes a snapping sound but can be controlled by finding a "happy" frequency. When I put my hand in the cubby hole in front of the mates seat I can feel the bulkhead and deck move with respect to each other. I can't tell if both or one is moving because my fingers don't have a reference. Has anybody seen or experience a rupture at this point? Have any suggestions?
The second crack showed up this season. I found it when I took the v-birth cushion out.
The gelcoat is separated from the glass. There are no marks on the outside of the hull.
