jennykatz
- Joined
- Dec 15, 2003
- Messages
- 1,679
- Reaction score
- 0
- C Dory Year
- 2006
- C Dory Model
- 23 Venture
- Vessel Name
- Little Treasurer
I have a 2000 honda 40 and the overheat alarm comes on within 10 min anything over 3000rpm ??
We have changed the impeller ,changed the thermostat and the pee hole shoots water out but it is very hot water also engine to hot to touch .engine compression is 85-90 all 3 cylinders .the engine runs great until alarm goes off. I've poured CLR down the thermostat hole and then taken the lower unit off and flushed it both ways from thermostat down and from lower unit up
So what are my choices ? flush again with salt away ?
How do you flush with muriatic acid ? How about putting engine in barrel and using CLR, vinegar , or muriatic acid ?? whats the consences out there ? need help
