Cockpit covers
South of Heaven
Aug 15, 2015
1,459
I checked some of the old threads on here about cockpit covers but they didn't really answer my questions....
The back story: When the boat is on the trailer I would like to keep water, leaves and any other unwanted things out of it! I currently have a drop down canvas door and a bimini cover.
1. Are the only cockpit covers the ones that attach to the roof and slope down towards the stern? Anyone have any pictures?
2. Since I have a bimini now; can I just have the Eisenglass pieces made to fit and essentially make a full camperback?....then could I leave the camperback up when the boat is on the trailer and use that as a cockpit cover? When a camperback is full up, are the edges water tight? Would a windy day potentially damage it?
I'm kinda leaning towards option 2 because then I'd have the camperback and a cockpit cover. LOL.
I'll put some pics of my new 19 in my album for reference.
Don't have a photo right now, but the "slant back" cover is a good solution. We just took the storage cover off, and will put the slant back cover on--and maybe even trailer with it on.
It attaches to the roof, the sides of the cabin, and he outer sides of the gunnel., then across the front of the motor splash well. It is pretty much water proof.
The camper back is another solution. It is far more expensive, but also very utilitarian. Some can be trailered in place. They have to be robust, and very tight, so there is no flapping--sort of like a convertible top. I would be surprised if you could get a side and back curtain set, plus zipper on the Bimini, for less than $2000. You may also want screens, where the windows zip out, and rollup on the inside or out side.
Yes, a good full camper canvas will keep the water out.
I'll try and get a picture of our slant back this PM when we put it in place.
I just took a look at your photos. It looks as though you have the exact same bimini as I do, which would make sense because I think JP Canvas made them for Three Rivers Marine as part of a typical upgrade package for the C-Dorys they sold. If so, I'd be a bit cautious about option two. Here's why:
1) The frame is relatively thin aluminum tubing.
2) The brackets that attach the frame to the boat are relatively lightweight plastic.
3) The screws that attach the brackets to the deck are "pointy screws into core."
With side pieces attached you'd be looking at more weight (possibly a fair bit more if you have eisenglass, trim, etc.). This puts stress on all the components, especially in windy conditions.
Note that JP Canvas is still in business, and I believe still favors aluminum frames even for camperbacks (more common is to use stainless tubing); but perhaps in those installations he uses a larger diameter tubing (maybe contact him and ask?). I would think he would then certainly use stronger attachment brackets (they can be had in metal as well).
I never intended to make my bimini into a camperback, but I have done a few things and can give you my notes.
a) I removed the brackets from the deck, overdrilled and filled the holes in the side-deck core, re-drilled them and re-attached the brackets, with new bedding. I can't actually remember if I cast the pointy screws in epoxy or went to through bolts with machine screws. I have strongly considered getting stronger stainless brackets, as these are rather weak (of course you then have to guard against dissimilar metals). I discarded the rusting "pin keepers" and used something else, but I can't remember right now what.
b) I had zippers put in the cross fabric "tubes" that go around the "roof" bows. As made the only way to get the bimini off the frame was to disassemble it (or take the whole frame off with the bimini intact, which was a bear to stow when trailering). Now I can remove the bimini and tow with just the frame up. I put an "X" of lines from one side of the frame to the opposite stern cleat on both sides; otherwise the frame wiggles around and stresses the (plastic) brackets. With the diagonal bracing of the lines it's rock solid (this is bare frame, when towing).
c) For awhile, when I was doing a project outside in a rainy spot, I took a blue plastic lightweight tarp and put it completely over the bimini (which was set up with the fabric on it) and clamped it to the roof overhang ahead of the cabin door, plus to stern cleats etc. This made it firm enough to not stress any one part, and gave me a dry work space. However I was in a very non-windy area, plus sheltered between other boats/buildings.
d) I have also used clothespins to clip sheets to the little side flaps of the bimini to provide sun shade while at anchor. But I don't know that I would do a lot more as it kind of weighs down the bimini (again this is in a non-windy spot).
So anyway, my feeling is that to make a camperback it might be easier to start from scratch. At the very least things would have to be systematically beefed up. I have seen Three Rivers boats that had JP camperbacks (looks like that was an upgrade over the "standard" bimini they used), and the actual canvas work on mine is quite good - it's just a "basic" design that Three Rivers likely specced.
Depending on how windy/rainy your storage spot(s) are, how much you want a camperback vs. a bimini, and how much you plan to tow --- another good optino may be to stick with this bimini as a bimini (perhaps adding the tube zippers) and then have a slantback for storage and towing (I wouldn't tow with a camperback unless very short distance or very specialized design).
How about a complete boat cover for when you store the boat? We use one and it keeps the cockpit et al dry, even up in the rainy PNW.
Bob: Thanks, I'll wait to see your picture of the slant back.
Sunbeam: At this stage in my cruising career I don't really need a camperback yet. I'm still a day cruiser for the most part and at the most would do a Friday/Saturday trip or Sat/Sun. It would be COOL to have one but not a priority right now. I'll call some local custom canvas shops and get some prices though, for reference at least.
A complete cover is definitely an option. I was just thinking that a cockpit cover would be great because sometimes I keep the boat in water for 2 or 3 days. I don't do it often but it would nice to close off the boat from the elements when I do.
Btw, do you have a picture of your cover? Where did you buy it? Custom? How much?
Thanks!
Here is a picture of a mooring (slant back) cover. It is loose because the owner was in the boat just before I took this. Done up tight, it would be over the outside of the gunnels, and cover the splash well. If I was doing it I would have covers for the OB's to match.
SleepyC :moon
Several of us bought our covers from Angola Canvas. Prices are good. They have patterns; hopefully for a 19'. I have a couple of pics in my album.
I have a complete, custom made, cover. Protects the entire boat. I paid about $1500 total for it, but well worth it. Lohaus Covers in Cottage Grove near Madison, WI did mine. I would imagine any good canvas shop that makes boat covers in your area could make one. Colby
Also look at the camper back cover made for Valkyrie. Their cover goes back further than the "factory option" cover, so it attaches way back in the splashwell. In use that gives more usable space inside and feels bigger. I had an identical cover made by the same canvas shop (we live nearby) last year. About $1300 if I remember correctly. They would be glad to make a matching and interchangeable mooring cover if I asked, and I'm considering it.
