Blackfish:
I've frequently had the problem you describe with my Honda 90 on fresh fuel. I'm running smooth, then take on fuel, and within a little while, am having problems with hesitation/stalling upon acceleration. The motor starts, and otherwise runs fine, but will hesitate when I call for more power while underway, and occasionally stall when I try to power up from idle. Seems that a lot of fuel is "bad" as it goes into your tank, no matter how recently you bought it. If you have a fuel source which eliminates the problem (your portable tank), I urge you to use that same fuel to test other parts of your system, and confirm the extent to which the problems are related to fuel quality.
The other reason I've come to focus on fuel quality with a Honda 90, and only then look to other issues, is the manner in which the fuel is delivered.
If the motor runs fine at WOT, and doesn't flood when it is stopped and then restarted, it seems to me you can conclude the following:
1: There is fuel in all 4 carb bowls.
2: The fuel pumps work.
3: There is not a blockage in the fuel lines.
4: The fuel filters are not plugged or significantly restricted.
5: The fuel tank vents are not plugged.
6: The fuel quality is sufficient to allow ignition at high speed.
If your batteries remain healthy, then you can also conclude:
7: The batteries are capable of holding a charge, and of delivering current to the motor so it can start.
8: Something is charging the battery: either the alternator, shore power, or both. If you boat for any extended period of time, you know that the alternator is working.
I'm sure open to suggestions, corrections, or qualifications on these conclusions. But, if they stand, then you can also go a little farther.
If the fuel system is capable of keeping the carb bowls full at all throttle settings (idle to WOT), then any defects in that system, such as clogged filters, plugged tank vents, clogged or collapsed lines, leaking bulbs, etc., etc., are of no consequence. They might cause other problems, but not hesitation/stalling in the manner we're experiencing. It's a fuel delivery system, and if the components deliver fuel to the carb bowls, they are doing their job. They might be doing that job inefficiently, and therefore should be repaired/replaced, but the problems with motor performance with full carb bowls cannot, by definition, have anything to do with "upstream" components. If you have any doubts as to whether or not your system is capable of keeping the bowls full, just idle the motor, push the throttle forward, notice the hesitation/stall, and then turn the motor off, and drain all 4 carb float chambers. I've done this time and again, and they are always full. Therefore, I've concluded that my problem is not one of fuel availabliity.
I'd like to get some thoughts on what IS causing the problem, but since mine is affected by fuel quality, I'm pretty sure I need to focus on what's going on under the motor cover. I know I'm taking on fuel that's got alcohol it it, tends to accumulate water, etc. and that the problem comes and goes with different tankloads of fuel. I don't know what adjustments, if any, can be made to the Honda 90 to allow it to be less sensitive to fuel variations???????????????????????/
Alma's Only
