Well-known member
- Joined
- Nov 2, 2003
- Messages
- 21,863
- Reaction score
- 211
- C Dory Year
- 2007
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- DOR25652A707
- Vessel Name
- thataway
Our Tom Cat only has one bow cleat, and it is athwartships and just aft of the windlass, so that if the line is attatached to it, and leads foreward it will hit the windlass casing on either side. (Not a good design) In our case, I made a line, with an eye spice, thimble and shackle which I place thru the bow eye on one end, and run a rolling hitch around the anchor rode with the other end. the rolling hitch will hold---and it tightens as the load increases. see:
http://www.animatedknots.com/rollinghit ... /index.php
I allow slack between the end cleated to the cleat and the place where the rolling hitch on the snubber line attatches to the main rode.
I probably will eventually add bow cleats to each side of the bow. or a cleat on each side of the roller... The boats don't come from the factory with any other bow cleats. There are spring line cleats on the side deck at about the foreward end of the wheel house--I think that making a bridle from these would be awkard and subject to chafe. (one might make a case for these to be bow cleats, but with the position as far aft and right on the edge of the gunnel, the line to the dock would be very short and subject to jerking loads.)
Some C Dories have a cleat on each side of the bow, some have fairleads with a single cleat in the center. In this case, one can place the snubbers thru the fair leads and then cleat to the center cleate (if there is no windlass in the way) Even smooth fairleads can cause chafe, so I would prefer to go directly to a cleat on the edge of the gunnel. If you pass a rope under load thru a fair lead, it is a good idea to have chafing gear.
Some folks anchor their boat so that all of the strain is on one side of the bow. I prefer not to do that, and to use two snubbers (at least one lighter than the anchor rode.) with one on each side. Thus the pull of the anchor rode is straight foreward off the bow. However, there is something to be said for anchoring with the bow slightly off of the eye of the wind--there tends to be less sailing--or more properly put--the sailing tends to be more in one direction. I have yet to own a boat which does not sail to some extent at anchor. No, I don't normally anchor by the stern as the only anchor.
