bmacpiper
- Joined
- Jun 3, 2007
- Messages
- 211
- Reaction score
- 0
- C Dory Year
- 2007
- C Dory Model
- 22 Cruiser
- Vessel Name
- Big Blue
thataway,
Thanks, that helps a lot to let me visualize what's going on.
Mind you, I run mainly in protected waters, but they get plenty bad for a little 16 footer. As many have noted, I am sure the 16 moves around more quickly/suddenly in rough seas (narrower beam, lighter weight), so here's one more question for you and the collective.
What about the possibility of using a drogue if caught in really bad stuff? For the record, my definition of a drogue is basically a sea anchor with a bigger hole in it, to allow use when a boat is making way with it deployed.
The thought here, based on your comments, would be to slow down the real sudden roll and yaw (in particular the yaw), but not add anything to the hull that would cause it to trip down the face of a wave, etc.
I've also seen a rig a time or two (intended for boats without power) that involved a triangle from bow to stern, with a pulley in the middle of the triangle. On the other side of the pulley was about 100' of line to a sea anchor. By adjusting the pulley's position, the operator could keep the boat a given angle off the seas when the motor had died, i.e. not with the seas directly behind as would be the case with a traditional sea anchor setup. It also seemed to create a slick to the windward side, which helped as well to keep seas from breaking next to the boat.
Here again, how about replacing the sea anchor with a drogue to allow use of the motor (slowly), but still get some assistance holding the stern in place as waves slide by?
OK, I promise this is my last post about this--but it is an interesting one for me.
Thanks and talk soon,
bmc
bmc
