Chart Plotter
ramos
Okay, I just vented on a different topic (warranty null & void) so now I can ask for opinions on a different subject. We have a 16C, so we do not want to spend an inordinate amount on electronics. We put a Garmin 300C fishfinder on it and like it. We do not have room for big displays, so I did not want a small split screen chart plotter/fishfinder. We are now considering adding a Garmin GPSMAP430. We would have a full screen (3.5" diagonal, don't laugh) fishfinder and, a dedicated (4" diagonal, I said, don't laugh) chart plotter. Think small, and let me know if my logic is on or off course. Thank You.
I like to have as large a display as you can afford, but if you are close--which I suspect you are in a 16--then the 4" screen should be fine. In my opinion the Garmin chart plotters are the easiest to use, the screens are bright and good. They are not quite as versitile as some of the others--but you are not going to be putting Radar and many other peripherials, such as AIS on a 4" screen. I think your logic is right on.
However, I assume that you want the inland lake's/rivers on the hard drive, rather than coastal information. Second you are aware that the 430 has been superceeded by the 431, which has some better features, including faster redraw time, and perhaps better screens. This also means that you should be able to get a substantial discount on the 430 over the current best price on the 431. If the price is the same, then go with the 431.
I'am aware of the 431 but, have not looked at the improvements because I have seen the improved price! Much to my chagrin, I have a budget.
Matt, have you compared the latest--that is the 431, 541 etc to the Standarad Horizon--There is considerable improvement. I agree that the latest Garmin is different--and take a little time to get used to. Perhaps in the long run, as there are more integrated systems (AIS, RADAR, Weather, etc) I believe that the plotters with the new soft ware will be both easier and faster. But it is difficult to change, since Garmin had used the same button sequences and standards for many years.
I have found that Garmin is always easier for less experienced folks to use--and the redraw time faster on the Garmin. (I have a Standard, Lowrance as well as Garmin I use regularly)
Plus and minus on the Standard is the map chips. They are good, but can get expensive, especially where as the Garmin has all of the lakes of the US built in--and they lake charts are good. (Or coastal if you wish). A plus on the Standard combo is that it does not require any wiring if you get the combo radio/chart plotter to see DSC locations on the chart--and for some this is very handy. I have been using Standard Horizon (Vertex) since 1965, and have some ham gear from the same manufacturer (Yaesu)--which is excellent.
The disadvantage of craigs list, many E-bay sites is that you are not dealing with dealers which will stand behind the product. Sort of like buying a new C Dory from one of these used car dealers who pick them up at the auctions!
There are a number of both good brick and motar stores which will match internet prices, and good internet sources, like our own Matt Unique, who are also dealers for the various products.
Can't help you with the conservative chartplotter, I tend to go overboard. I'm really happy with my Garmin 5208 and I don't think its too big for the 16 Cruiser myself and the touchscreen is a big plus. With space being such a premium in a 16, I have thought long and hard about what was going to take up any space onboard. Avoid uni-task items when possible. Pricey though as I have equipped it.
Seabeagle,
It is impressive what you have managed to squeeze on to your' boat, however, my budget will not allow me to even come close to what you have installed! My only complaint with multi-task units is that you risk losing multiple tools at one time. It happened to me at one time with my "state of the art" loran/depth finder (yes, that was a few decades in the past). Keep in mind that I cannot afford multiple multiples. I'am trying to cover my bases from a minimalist position. I did look at the Standard Horizon 180, seems that the graphics may not be up to Garmins' level out of the box. Upgrades (chips) seem to be more expensive, and I do not think I would be as likely to need to upgrade the Garmin unit. It is all a little confusing. I want to buy once, buy smart and be satisfied that we spent enough but, did not over buy. Hope this makes sense, I'm not much of a wordsmith!
What are all the radios for?
You might look around eBay for a Garmin 176c or 276c. They aren't the newest or fanciest, but they are a portable chartplotter with a decent 4" screen that can run on 12v or AA batteries and can be found pretty reasonable on the auction sites. The Garmin BlueChart chips are not inexpensive, but those can also be found on eBay. As I mentioned recently in another thread, I use a 176c as my backup GPS; used to use it in the truck, but have updated to a Nuvi. I turn on the 176 right along with the Raymarine - keep the Raymarine set for track-up and the Garmin for north-up, on different scales. The Garmin was our main GPS on our sailboat for a few years before the C-Dory.
Bob-
I like the resolution of the displays on the Garmin, and their charts are good, but the system of getting into the setup menu to change settings requires multiple key strokes, and then the exact same number of key strokes to get back out of.
I used Garmin 540 this year, and just found the menu sytem cumbersome.
The systems I prefer allow a one or two button exit from the menu back to the page I was using.
Ron
If it were me and I was concerned with space I’d buy a Garmin Colorado 400c hand held GPS. I’ve got one for a backup and mount it with the suction cup holder next to my Garmin 172c; it does a fine job without and external antenna. When you stick it right there in front of your face on the dash the readout if great; I’ve never understood the giant screen fixation on one of these little boats, but to each their own.
Garmin 400c
Seriously, this is a nice GPS and West Marine has them on sale now for a tad over $300. It comes loaded with marine Blue Charts already so you don’t have to spend extra. We use it all the time when going ashore or taking hikes around Alaska, and you can buy road maps and mount it in your car.
Have you considered a hybrid unit like the nuvi 550 preloaded with maps? It is discontinued and marked down to $249 on Amazon
It works on highway, offroad and on the water. It was a 3.5" color screen but the deciding factor is the maps. The screen resolution is 320 x 240 pixels (QVGA volor)
I have a Garmin 545s (s=sounder) with coastal maps purchased for $800 with 640 x 480 pixel VGA resolution. . The map upgrade was $200. Panbo reported Garmin will release PC based (no MAC OS) mapping software for $30 in Nov, 2009. You download the installed maps to a 2 G SD card ($9 Walmart) and connect to PC with memory card reader. Open software and starts exploring on your PC
I think I have it narrowed down to two units. I want to stay with a marine unit so I have the option of upgrading and adding to the maps.
1. Garmin GPSMAP 430.
2. Garmin GPSMAP 431 (new/improved 430).
Price difference of $140.00 gets you faster re-draw and better graphics. I'm not aware of any other changes but, there could be more.
Any more thoughts?
Jon
These models lack the S suffix therefore do not have a sounder (FF/depth). I thought you wanted this feature. Maybe you meant 431S
One weekend after work, I went to the Indy Gander Mt and all of models were in demo mode and little customer traffic so I tried each one for 2 hrs. Admiral was delighted b/c I brought roasted chicken and ribs, and wine. I liked a Hummingbird model for ease of use and maps and I ordered one online but it was back ordered for an indeterminate amount of time so I canceled it and ordered the Garmin but the transducer with speed sensor was out of stock and ordered one without it. I am glad I went to G Mt. I just installed and it worked fine with just a time spent learning some advanced features like alarms, MOB, show speed and display, etc. It was a great color VGA screen
good luck
breausaw said:
Ron
The smaller chart plotters are fine if you are going slow, or hiking, where you can hold them up to the face. But if you are running fast, the boat is bouncing around, you just cannot read enough detail on the smaller units to be safe in unfamiliar waters.
This was brought home to me again today. I have two 7" screen plotters on the Tom Cat--half of one of these is fishfinder/depth finder, and the other half, long range chart. One 7" plotter is dedicated to detail on the one mile or closer scale. Bouncing around going 30 knots, you cannot read the smaller detail. I own both a Colorado and a 76 SX--nice chart plotters--great for the dinghy--back up etc--but not as a primary navigation tool. It has nothing to do with the size of the boat. It is also nice to have the chart plotter just below your line of vision out the windshield--so you don't have to bring your eyes any distance to locate the study the plotter.
breausaw":2t9rrfji said:
Ron
Those of us in small boats sometimes feel inadequate and have to make up for it with big jewelry on it. :cry
