Les Lampman
drjohn71a":3syap2kr said:This all seems like a bit of overkill to me, as well as injecting an opportunity to foul both engine's filters with bad fuel accidently.
I mean, the thing holds 300 gallons of fuel... How much do you use trolling? At hull speed, that is about 6 gal per hour, or 50 hours of motoring. Or 300 miles of traveling without keeping track of fuel? I don't really see using one engine as a significant drain on either tank.
Each engine has it's own fuel monitor on the Honda digitals including flow, hours, total gallons used, etc.. So just look at your gauges and rest one or another of the engines if you want equal tanks.
And, if one tank has some water in it and you get in rough water with both taps open... now you have NO engines running while you go aft to drain the water from the filter bowl.
But, you guys have done so much great work to that boat that I really admire. I'm just more of an 'end user' boatwise. I want to spend minimum time working on the boat's hardware!
Thanks for posting,
No boat of any kind, shape, or size with two engines and more than one tank should be without some method of isolating tanks or choosing which tank to use whether for balancing the boat or isolating a tank with a problem. No commercial vessel would ever operate on a one engine, one tank basis and neither should a recreational vessel since it severely limits your ability to deal with emergencies and failures.
If I'm in the middle of timbuk nowhere I want to be able to isolate a fuel tank that's ruptured, whose fittings failed, or that was contaminated and run both my engines off the "good" tank.
If the boat is loaded heavily to one side I'd like to be able to burn fuel off that side in order to level things out a bit.
If you do this when the boat is new you can run a tank completely dry before switching to the opposite tank; this keeps you from building up crud in the bottom of the tank which you can't do otherwise because in the one engine, one tank scenario you can not afford to run dry.
It isn't a complex system at all; it consists of three on/off valves designed for the job they do (that is, they're gasoline rated). There is an inline valve between each tank and the engine on the same side and one cross-over valve.
Three conditions exist (typically):
1) The cross over is closed and the two inline fuel valves are open...each engine draws fuel from the tank on its side.
2) The cross over is open and the port valve is closed...both engines draw from the starboard side tank.
3) The cross over is open and the starbard valve is closed....both engines draw from the port tank.
The thing is if you prefer to operate with each engine drawing from its own tank that's fine, just leave the inline valves open and close the cross over. You don't have to run through the cross over. The beauty of this system is that you can if the need arises; also if you prefer to balance tanks you can. Shoot...even the CD22 gives you this option.
