Time to get on my Carbon monoxide soap box. The reason is that as a physician I have treated (and pronounced dead on a couple of occasions) victums of CO poisoning--several of these on boats.
To compound the issues, the UL labs dumbed down the CO detectors because of too many "false alarms" runs by paramedics. " The UL standard 2034 (1998 revision) has stricter requirements that the detector/alarm must meet before it can sound. As a result, the possibility of nuisance alarms is decreased." Sounds good?--wrong, it means that you have a higher level before the alarm sounds.
Carbon Monoxide binds into the hemoglobin in the red blood cells which carry oxygen. The Carbon Monoxide binds faster and 240 x more strongly than oxygen, deprieving the tissue of the body of oxygen. carbon Monoxide poisoning is insidious. It is cummulative. That is a chronic exposure to a low level will eventually cause toxicity as the blood CO level rises.
There is a finate limit on the longivity of the CO detective mechanism. They are not good for longer than 5 years and some manufactuers suggest replacement at 2 years. Heat degrades the sensors--and if you leave the sensor in a hot boat or car--replace the unit at 2 years.
I personally like a battery operated unit which has a digital read out: The Kidde Nighthawk 900-0089. (this is 9 volt; there is also a 3 AA battery version) @ $40. If you want the best of the consumer grade product (fire fighters, house inspectors and heater technicians etc use expensive professional grade instruments) consider the more expensive CO Experts 1070. @ $129
The Nighthawk is "blind" to concentrations less than 30 parts per million. The CO Experts starts to read at 5 parts per million, and it gives a much better commulative estimate of exposure.
http://www.aeromedix.com/product-exec/p ... Model_1070
Below is taken from the CO Experts site:
CO Concentration
(parts per million) Symptoms
35 No obvious symptoms after 8 hours of exposure.
200 Mild headache after 2 to 3 hours.
400 Headache and nausea after 1 to 2 hours.
800 Headache, nausea and dizziness after 45 minutes; collapse after 2 hours.
1000 Unconsciousness after 1 hour.
1600 Unconsciousness after 30 minutes.
I suggest installing the detector near where your head will be when you sleep. Also the CO experts is not "approved" for boats, because of the risk of lower life span in higher humidity areas. If it is kept in the cabin, this is not a major concern.
