In the fall I winterized the engine, it was running fine. I removed the batteries for the winter and put them back in yesterday. Lights/ wipers/engine tilt etc have power and work. When I try to start the engine I get nothing except an almost unnoticeable "click" coming from the engine that sounds like a relay, its not the starter. I cant imagine what could have happened between fall and spring that would explain this. The throttle is in neutral and the safety clip is on the switch near the ignition. My friend that is a car mechanic said the small wire going to the starter (on a car) should have 12V on it when the key is turned...that voltage is not there on my engine. Im not a mechanic but off hand I would suspect a neutral switch that stops the engine from starting in gear. The safety switch near the ignition switch, something called the starter switch relay a bad ground. The grounds I removed and inspected were tight and clean. If you could share any ideas it would be appreciated.
