Ctarmigan
- Joined
- Nov 14, 2019
- Messages
- 57
- Reaction score
- 5
- Location
- Whitehorse
- C Dory Year
- 2004
- C Dory Model
- 22 Cruiser
- Hull Identification Number
- CD022102J304
- Vessel Name
- Ptarmigan
Hello all,
We have a Toyo NS2800 cabin heater on our 22. It's wonderful; lots of heat and low fuel consumption. With a two-year-old on board, this really extends our season (which in the Yukon can otherwise be rather short).
I've been doing some maintenance on it (dealt with a small exhaust leak at the fuel nozzle), and would like to replace the vent tubing. It's currently made of 2" ABS. This has held up remarkably well, only a little deformation near the heater output, but I'd rather use something better suited to moving hot air. Presumably, breathing aerosol ABS derivatives isn't good for us.
What have you used for vent pipe material for cabin heaters? Do I need to go with something specific, or is there a widely available material that can be repurposed? I'd prefer something rigid, based on the configuration I'd need, and would need to incorporate both a 90° bend and a t-junction. Heater output is 65mm diameter.
Cheers,
Oliver
Cheers,
Oliver
