Cabin door design
pcg
Aug 31, 2018
467
15
1999
DOR22866J999
I’m looking for design input. As some of you know, I’m in the process of restoring a 1999 C-Dory which was damaged and sunk overnight. Basically I’m starting from a bare hull and am making many minor and some major changes as I build the boat back like I want it. The current cabin door is quite warped so I have the opportunity to replace it with something better. Already in the works are a 3-point latching system and a sliding screened window. Yesterday I bumped my head going through the door opening and realized there is room to make the door opening at least two inches larger in height. I wish I’d bumped my head and realized this sooner so I could have purchased a window that was also two inches higher, but too late for that. So now I have to decide how high to place the new window in the new door.
I have zero experience with a 22’ C-Dory so I’m asking you experienced skippers who have spent many hours looking out that window from the helm seat - would you keep the location where it is or raise it higher? If you would raise it, how much? Thank you for your input!
The CD22 has a low window height. It is fine when sitting, but too low when standing (at least for me). The Venture 23 and 26 have taller windows that are better (IMO). If you compare the roofs of the CD22 with the Venture you see that the CD22 has a raised center section for head room in the cabin while the Venture does not because the cabin sides are taller. If I was completely rebuilding a CD22 I would seriously look into either taller windows or mounting them higher. This probably requires taller cabin sides though.
In the case of the door, if you can't increase the size, can you move the door and cabin opening higher? This would make stepping into the cabin a little different but might spare your head.
Yes, I have banged my head on the top of the cabin door opening many times.
I can increase the size and the opening of the door by at least two inches in height, so the lower location of the opening stays the same, but there will be 2" more headroom. I did raise the roof 4", but only in the manner of a hightop. I like your idea of raising the roof by raising the sides so the side windows are raised as well. This would give more useable space at the galley as well, but too late now. :( This is exactly the kind of input I was hoping for. Thank you!
My CD22 had the cabin door replaced before I purchased it. It was replaced with a solid glass door which I find very convenient. It allows a great view of the cockpit and engine while closed. This is useful for visually confirming the 'rudder' angle of the engine and status of gear in the cockpit it rough sea conditions.
You may want to take a look at a 25' cruiser. Mine is an '07 and I have a glass door which allows complete view to stern which is really good especially when navigating with other boat traffic in the area. Good luck.
The other “solution” is to put a camera outside of the cabin, showing the view aft. I believe that is what my son did with his 1995 Cruiseship.
