Does anyone have a wiring diagram for the C-Ranger 21? I would like to know how the Batteries, Isolater, Power Switch and Guest Charger are all connected to each other.
It appears that the motor is directly connected to Battery #1, and so even when the main switch is off the motor will start. John stated this is done so it will not blow out the diodes in the alternator if someone turns the battery selector switch.
So, if for some reason if Battery 1 is dead, then I'm assuming that I will not be able to start the engine from battery two by simply selecting the battery switch to Two, but would need to "jumper" it in the engine box.
