C-Dory Factory Pics
Jack,
The foredeck house area has a slight curve to it in the middle of the fore and aft vertical section, approximately 1/2", however if you go further forward I found the curve to be more in the 1/4" range so I would recommend installing it further forward. Easy check to do is just lay a straight edge along the foredeck vertical fore and aft section and you will see what I am referring to.
Let me know if you need further advice.
Scott
Scott,
How about some pictures of the finished cockpit floor with hatches and head in the 25. Thanks.
Rob
Scott
Thanks for the model #s, advice, and your supplier. I called them and have the port holes on order.
