Just got back and I have to say. Man what a boat!! It is a topnotch boat just like the Cdory, although there were some big differences. The main ones I noted were:
1. the Hull, it definatly has more V, but I wouldn't call it deep V as its pretty flat in the back too. And has a flat spot in the middle that the Cdory does not have( I believe). It planed out quickly at low speeds, and handled very nice.
2. Transom- major improvement in my eyes, better battery storage, and even though you lose the side storage in the cockpit you get some here, that helps to make up for it. Also helps keep big waves out.
3. Flat floors both cockpit and cabin. Both floors are foam filled and flat, with nonskid molded in. the cockpit floor actually slopes back a bit to help the water drain to the rear of boat. This also was a big one for me, and just made the boat look more finished to my eye. And the boat is just as deep as a Cdory( no worries about falling out) and has a bit more flotation.
4. Cockpit lights under gunnels, and fresh water deck washdown come standard. Two features which I have in my current boat(defiance) which I would not be with out (if you fish)
5. 30 gallon aluminum gas tanks.
6. Smaller cook area, 1 burner wallas is standard but they can fit in the two burner if wanted. space around is a bit smaller.
7. Table design. Looked much sturdier and easy to deploy or put away.
8. Fiberglass cabinets, instead of wood. (Easy to wash, and one molded piece)
9.V berth a little taller, and has a hatch to seperate rope locker from V berth.
10. Roof taller all the way across and made to be load bearing. It even has nonskid up there.
11. Longer wrap around bow rail.
12. Wider, longer , heavier. 1000lbs heavier than Cdory advertised weight(22cruiser)
13.Faster, less pounding. Twin 50 hp is what the boat that I tested had on it. It seemed to go quite a bit faster than the Cdory I have been on, and took the waves a little gentler. They also said it gets very good gas mileage similar to the Cdory.
Overall I loved this boat!! It rode well, has a great layout and suited what I am looking for better than a Cdory. I'm sure not everyone will find it that way, but they definatly make a high quality boat. I don't agree that this boat is more of a fisherman, and less of a cruiser than the 22. Or that it is a pumped up arima ( I had one, now that is a way different boat) C Dory, and Cape Cruiser are too similar in size and layout for that to be the case. and as far as that goes the 23 is bigger, and should cruise nice too. I think that both boats would make a great fishing or cruising boat. I was also impressed by the salesman and the staff, they all seemed honest and up front. They never said a bad thing about Cdory, and actually paid tribute to them. They also explained that when Cdory was sold, the Toland's sold the molds only, and they held the right to redesign or modify their own original design. Which makes sense to me since they came up with it in the first place. I felt they let the product speak for itself rather than bad mouth anyone, and I give them props for that. Anyway, I 'm going to purchase one if I can work out the finances, and I think they are a great boat too. I'm sure they will have a following just as the CD's do. I just don't see why people like to divide themselves so. The cape cruiser is from the same designers as all your beloved Cdory's, they are the same family of boats. They both are great boats!! Any way, this is just my opinion, nothing more than that. So don't take it too seriously.
Hope to see you on the water
Sark
